If this is your first visit, you will have to register before you can post. To register, click the Login or Sign Up link located at the top right of the page. Once you are logged in, you can start viewing message content in the subforums listed below.
PLEASE REGISTER FIRST, LOG IN, THEN JOIN!
If you are seeing this, it's likely that you are not logged in. If you are a registered user with an account, just log in and proceed to join today. If you are not a registered user, then please register and log in to be able to join the club. Thanks!
ATTENTION:We are aware of some passwords being reset after the recent vBulletin upgrade. If the site tells you that your password isn't valid, please do the following: 1. Use the reset password link provided
2. Verify you received the email to reset your password
3. LOG OUT OF THE SITE (this one matters)
4. Reset your password with the link in your email
5. Log back in and you should be all set.
If you have additional problems, email the admins at [email protected]
All S2000 owners and safe drivers welcome to the open track event at Grattan Raceway, October 10 & 11. See attached PDF application. This event is run by the Detroit Alfa Romeo Owners Club (no S2KCA in Detroit). Info can also be found at - http://www.arocdetroit.org This is a two day event with the track being run in the opposite direction the second day, very fun. Thank You!
Runing Grattan anti-clockwise has got to be outrageous. I'm trying to run it through my head right now.
Right-hand semi-blind then downhill while staying on the right side
Left hand hairpin with a blind out-track into a sweeping uphill left then
Hard left to an
Uphill right down into the "bowl" then
Off camber left down into
#6 right then
#5 left to the "bump" on the run to #4
Holy smokes #4 through #3 and then #2 must be tricky as hell. Entry to #3 must be near-flat in tight but off-camber for a late apex and a nearly blind track-out up the hill to #2 and #2 must be semi-blind to the track-out.
