Hi everyone, I was talking with a member here and he said to ask about this problem that I have. Well a couple of weeks ago I notced that at idle the dashlights were flickering. Any Idea's?
Dashlights dimming?
Had the same problem over a year ago with my 02, new alternator fixed itCoop
Life Member 57
Friends do things for friends because they matter, thanks Sean, Jeff, David & Curt. Camping time
It's Five O' Clock Somewhere
Become an S2KCA member, tell them Coop sent you
This is what I noticed about his car.
On startup, the lights were fine. When the air pump turned on, they start to flicker at the same frequency that the the air pump runs at. His car is an AP1, but I don't know the YM. It only does it at idle, too.JW
Cannondale Six13
LOOK KG 381
Klien Quantum Race
When you start the car it does not rest at normal RPM's, it goes higher (1500-2500 depending on weather I guess). When the car goes back to normal, "resting idle" RPM's (600-800 I think) then there is less voltage being produced. That equals the SAME reason that it doesn't do it while driving. It's all related to voltage. Whether it's the battery or the alternator, there's a voltage problem. Remember, the batter provides the power, but it has to have something behind it to "fill" it up...( I knew 15 years in car audio would pay off eventually
